wiring harness removal
cb_240
Car: 1993 Nissan 240sx SE, RB25DET swap
i've been asking on different forums, and have been searching but no one seems to know or wants to take the 2 secs worth of typing to tell me
how do i remove the upper harness out of an s13 with abs
the engine is out so everything is disconnected from there, the other end of the harness in the engine bay is unclipped from all the sensors and whatnot, and its disconnected inside from the ecu and whatever that other wire is. i followed it under the abs where it goes through the fire wall from the outside and found it on the inside but have no idea how to get the damn thing out.
do i have to remove it into the engine bay or into the inside of the car?, Do I have to remove any of the abs crap or the dash?
and when referring to the lower harness is that the harness that goes from the battery and connects to the under side of the engine(starter and everything) and goes to that fuse box on the passenger side
please help!!
neverlift
your correct abou the lower harness. You should be able to just unplug everything and disconnect any grounds and pull it out.
as for the upper harnes you are gonna need to muscle the clip you cant reach.(break that mutha fugga)
cb_240
i have that clip broke off on the inside, but what do i do to get it out of the car
that black rubber ish piece is in the hole where the wiring goes thorugh, do i just pry that out with a flathead screwdriver and feed the wire out?
cb_240
i got it, i pryed the black piece out and fed it out
