wiring harness question
fallen180sx
Car: 90 Sil80
weve wired up the engine harness but i need a ka to ca diagram of the accessory harness.. or the plug after the ECU. i need the diagram so i can splice the goods up
biosehnsucht
do you mean the harness going to the dash? or the brown and grey plugs near the battery?
fallen180sx
Car: 90 Sil80
harness going to the dash.. the plug that goes... white plug----ECU----engine harness the plug that goes inside the foot panel
fallen180sx
Car: 90 Sil80
gah i need this now!! lol.. its the plug thats white. the plug that goes to the ignition, dash, radio, climate control.. blah bleh..
crazymax
Car: 89 coupe
Yellow / Red stripe Tachometer signal Yellow / Green stripe Speedometer signal Orange Ignition start Black Ground Blue / Green stripe AC signal Blue / Black stripe Water temp signal
On the KA, the rest of the wires are listed in the KA FSM as going to the 'check connector'. It is not necessary to connect any other wires to get the SR to run properly.
This? its just color to color
fallen180sx
Car: 90 Sil80
whats fsm? thanks you just got my car almost running
biosehnsucht
if you do hook up the 'check connector' wires properly you can then use gizmos such as the techtom mdm-100 or vlogger or other consult-based devices... nifty but not necessary..
FSM is factory service manual.
you can download the CA FSM from the FAQ thread at the top of the forum I think, somewhere. As for your KA FSM you'd have to own one or know someone that does, for your year. There are various FSMs floating around for US cars but not for the 90. I have an 89 which is mostly the same but I'm not at home right now so ...
fallen180sx
Car: 90 Sil80
alrite we got the dash goodies hooked up. whats the diagram for the 2 plugs behind the battery?
biosehnsucht
that too, unfortunately, is at home..
if you haven't got it worked out when I get home I can post it up
fallen180sx
Car: 90 Sil80
ok if the 2 plugs behind the battery were not hooked up.. would it not start? and when do you get home? this is the ONLY thing keepin it from firing. it rolls over though
biosehnsucht
yeah those 2 plugs provide power to the ECU, AC control from the ECU, a few other things like neutral position sensor and such..
fallen180sx
Car: 90 Sil80
ok we wired it up by the sr chart off srswap.com.. but it idles for like 2 seconds and just dies.. im guessing bad spark plugs.. were putting them in now
biosehnsucht
probably not the spark plugs.
check for codes from the ECU. turn car to 'on', then use a screwdriver on the little adjustment thing, turning it all the way to the right, and it'll flash twice, pause, three times - when it flashes the third time turn it all the way back to the left.
now it should after a second or so start flashes codes, first the red X flashes and green Y flashes after that IIRC.
the codes are refered to in XY fashion i.e. 5 red 5 green is 55, 55 is all is ok (to the amusement of all who have a small bit of japanese understanding, the japanese word for the number five is 'go', hence the everything is ok code is 'go go'..)
I forgot the other codes, I think 12 is MAF ... find the FSM (search forum for links to PDF, ther's one on zilvia.net but its missing some pages in the engine mechanical section, good enough for what you're doing though) ...
fallen180sx
Car: 90 Sil80
ok it runs now, but wont rev past 3,000 rpms.. we cleaned the MAF. the o2 sensor isnt plugged in though.. anything?
crazymax
Car: 89 coupe
You getting any codes at all?
fallen180sx
Car: 90 Sil80
yeah code 34, were hookin up the knock sensor, but theres 4 wires on the KA and 2 on the CA... so were tryin to work with it.
fallen180sx
Car: 90 Sil80
long story short, the ka side has 4 wires.. a pink with blue stripe, a yellow with blue stripe, orange, and black wires. the CA side has 2 wires, white and black. this is the knock sensor.. what wires go to what?
S14R33
Car: S14
Hi hope you suss the problem, have you tryed the throttle position senser?
fallen180sx
Car: 90 Sil80
dont think its that.. although im using the ca transmission harness.. wonder if i use the ka transmission harness will everything plug right up
biosehnsucht
You'll either have to connect the det sensor directly to the ECU harness or rewire stuff car-side.
on the CA ECU harness white connector by the battery there should be a white wire there, and diagonally adjacent to it is another wire (black? not sure color its not specified) these two are for the white and black wires on the det wire.. the black is actually just a shield wire, the white is the actual signal.
when we rebuilt my harness we just connected it straight from the ECU and ran it under the intake mani from where the ECU harness comes out of the firewalland goes up behind the engine.. originally it goes through that connector by the battery tray, then through the body harness to the lower engine harness where the starter/alternator/transmission stuff is.
float_6969
OK, the CA ECU Pinout and ECU Codes are now in the FAQ....
