Wiring Harness question
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
ave86th
My Versa also doesn't have radio and I am planning to install an aftermarket radio. I read the article on http://www.nicoclub.com/articles.php?id=227206. It was very helpful. Following the suggestions in other forums, I purchased a wiring harness since I don't want to cut the original wiring..
I have installed radios several times on other cars but still I don't think I have that much experience.. If I am missing something basic please don't be harsh on me.. So, my question is: My harness has 11 wires on it. 8 for speakers, 1 for ignition, 1 for 12V, 1 for amp. But there is no black wire for ground.. Is my harness missing a wire, because the radio I have has a black wire for ground?
Thx in advance & happy holidays
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Just ground the wire to a unpainted metal surface on the car and all should be well.
williamk10
Car: '07 Nissan Versa SL
Ground the aftermarket wiring harness ground wire to the chassis. As I recall when I installed my deck, there was no ground wire on the OEM harness to connect to.
ave86th
Thx a lot for the answers. So, I will need to ground it afterall..Probably I am gonna order another harness, it is just 1$ anyway.Happy holidays,
XterraVersa
Car: 2002 Nissan Xterra
Nissan 350Z Nismo
The factory HU was grounded using its chassis and metal brackets, that why there is no ground wire in the harness.
reyg89
Car: 07 versa s
ground the ground wire from the deck harness to the metal bar that is behind the radio, use a star washer and a self tapping screw to do it like the pros
rafboy
Car: Nissan Versa 2008
Hi. I have the same grounding problem.Where is the metal bar behind the radio?I looked all over inside of my dash and only saw plastic.Thanks in advance for the help!
kartracer90
Car: 03 Mazda Protege5, 07 Nissan Versa
If you dont see the metal bar just extend your wire and run it to the kick panel area and ground it there
rafboy
Great. Thanks.So... where's the kick panel?
kartracer90 wrote:If you dont see the metal bar just extend your wire and run it to the kick panel area and ground it there
Return to “Versa Technical Discussions”
