mcochran1 wrote:New member, but have been visiting this site for about a year now. I am in going to install a JVC single din headunit in my 08 altima sedan, non bose. The JVC wiring harness has 2 more wires than the wiring harness adapter that I bought for my car. I have been told that this is the correct harness, but I just want to make sure before I possibly destroy my headunit. The wires that don't have any corresponding wire on the adapter are Black wire and a purple and white striped wire. Do I just cap them off or tap into another wire....Please help. I have searched for hours and unable to see if anyone has this same problem. Thanks in advance
The black is probably a ground wire (should be connected to the sheet metal of the car). I'm not sure what the purple/white is. Didn't some instructions come with the harness? You likely wouldn't mess up the head unit without connecting the wires, but it probably wouldn't work correctly (it certainly wouldn't work if you didn't connect the ground).
