Wiring Harness Question, Nistech, I need your expertise
tiger
Ok here goes...
The guy that owned this car before me cut a lot of wires in the dash and up front. When he sold the car to me, the gauge cluster did not light up, the odometer and trip did not work either. This guy had some wierd stuff wired up...I just thought i'd exchange the dash wiring harness... I did that and car wouldn't start... so then, I went to the Junkyard and found a 93(same year as mine) 240sx with a trunk... (I have a hatch) I took all the wires from the driver and pass seat up... I had to cut it where it ran along the left side of the driver seat underneath the carpet. I figured i'd just wire the tail lights and fuel pump in later. Fast forward a couple days and I have the new harness in... There are some connectors that I have never seen before in the engine bay, I figured that they just plugged up to useless stuff that I didn't have on the car anymore. I was in a hurry to see if I had ignition power and I connected everything but the wires to the rear of the car... just tail lights and fuel pump, right? Anyway, I plug in my instrument cluster and try to turn it over.. I hear a click coming from the fuse panel... I'm really frustrated and I don't even know where to start checking for a problem. I noticed by the ecu that the guy before me had done a lot of wire cutting there ... could the ECU wiring be configured to work with the ****ty cut up harness that was on there.. ? Hopefully not, can someone tell me where I should start?
tiger
Ok I'm sorry but these pics may be a little blurry, it's only my phone camera. This one is of how hacked up the ecu end of the engine room harness is. I am thinking maybe the engine room harness is conflicting with the main harness...as far as wiring goes.
tiger
In this pic... you see the lower part of the engine room harness that connects to the main harness by the fuse box.. coming out of the engine room harness is... a ground wire(that's grounded on the body) the large power wire that goes to the starter... and 4 connectors... there are 2 that have already been connected, as for the other two, I dont know where to plug them, i believe they are just for the neutral position switch and whatever else that connects on the transmission. I want to see where they plug in... the connectors I dont know where to plug are circled in blue...
tiger
ok on this one there are 4. I have a 93 hatchback M/T.. this wiring harness came from a 93 A/T Hopefully one of you reading this can go out , if you have the same car... and take a look at yours and let me know what I need to do! Thanks
Modified by tiger at 12:53 PM 7/12/2006
Modified by tiger at 3:17 PM 7/12/2006
tiger
ok, I found2 plugs, they go to the clutch interlock relay... that might be why the car is not starting.
