wiring harness identification
jautoS13
so i purchased this harness for my ca18det because mine was spliced at the firewall. and it look kinda the same but it is missing about 5 or six plugs from the original is it possible to tell if the harness i got is from an sr... because it sure does not look like ca18det.... second of all i did a search and could not find anything relating to this. and i have a US automatic harness and there different as well. identification please help if possible i will take photos and post soon...
nitrohuffer
SR20DET harness will not plug into CA18DET computer first off. CA18DET's have a plug for the injector resistor box the SR20DET there are others like injector plugs are totally different water temp plugs are diff, cas plug, tps. ficd, iacv etc...) if you don't have a part # tag still on it.
jautoS13
thanks i just found out it is a ca18det harness except its a UK version LHD go figure but its missing the power transistor plugs i guess it is wired to the chassis so i have to hard wire big headache but thanks for your help i couldnt tell some one came and looked at it yester day
