Wiring Harness for M/T transmission
Impulsevert
Car: 240sx Vert
Anyone know where I can get one? I'm buying everything for the 5 spd swap but the person I'm buying it from does not have the harness.. any knowledge on where I can get one?-thanks
Eikon
Car: 71 240z, 93 Supra TT
I'm planning to do a swap next weekend. I've been collecting parts for a very long time. The one part that I couldn't track down was a harness.
After discussing with tenkawa_akito it sounds like the harness is not necessary. You just need to manually wire a couple things and your set. I'll track down my notes and post them up..
cheap_sticker05
Car: 1994 Nissan 240sx VERT! 1995 240sx
I just did mine last weekend. I did not use the harness. I don't have backup lights but everything else works. If you are using a auto ecu then the manual transmission gear sensors do not do anything.
Impulsevert
Car: 240sx Vert
Oh ok, thanks yall, I thought it was somewhat necessary for it, guess not
madcowvert
nope you only need it if you want back up lights
Eikon
I guess you can run your own set of wires from the reverse sensor to the inhibitor plug. That should get your back up lights working...
i think it's in the 5 spd swap thread somewhere..
TurboChargedSE-R
Car: 1993 Nissan SE-R with a BIG turbo
1993 Nissan 240SX convertible KA24DE-T
Buy a new reverse switch from Auto Zone for $15, and wire that to the fusebox on the passenger side. Reverse lights will work just like they should.
