wiring harness extension
goixiz
Car: Cycling and cars
WEhat is the best way to join to extend the harness for an sr20 swap ?
If parts needed where can i get them and how many do i need ???
Thanks in advance
yellow_jacket
Car: 95 240sx
The best way to do it is to solder it. You will need solder, flux, and of course something to produce sufficient heat(soldering iron etc.). Then you can either use shrink tubing or electrical tape to cover the soldered joint. Do NOT use crimp connectors or just twist the wires together! Have fun!
