Wiring gurus, I need your help!
EnemyRb25
Car: 1995 Nissan 240sx *RHD with a S1 Rb25det
I am using a S14 (95) Jdm Chassis and Dash harness on my 95 USDM RHD conversion. I am retaining the USDM upper and lower engine harness. I have almost everything wired up and I have a couple of problems that I hope you guys can help me with.
1: Jdm Wiper motor is constantly running, regardless of what wiper speed I set it on (jdm wiper switches). Thought about taking out the internals from my Usdm wiper motor and installing them into the Jdm wiper motor.
2: When I use the turn signals (Jdm switches), the side bumper markers work, but the corner turn signals don't work. (everything should be plug and play, to my knowledge, but I seem to have this problem)
3: I am using the USDM rear chassis harness. I know the JDM dash harness pins do not line up with the USDM rear chassis harness. I am wanting to find out what JDM pins corralate with the USDM rear chassis pins, so I can repin them in the correct place. (When I plug in rear chassis harness into the dash harness, obviously nothing lights up. When I switch the turn signal to the left, I hear the antennae motor turn on)
Thanks
