Wiring Gurus, I need some help with a few wires...RB20 into hardbody pickup
s13_240_rb20
Car: 1990 240sx RB20DET
OK...I have a thread already started in the "Nissan Trucks" section:
zer...dance
But I think that my problems can be better answered here since my problem is more about the RB engine's wiring. Some of these RB wires, I will just have to find a suitable power source, so I need to make sure I know WHENNNNN these wires receive a POS or NEG signal (keyed-2-start, switched, constant, ?????)
With the white/purple, black/red, and white/black ALL connected directly to 12+POS, the key starts the engine and it idles....But I need to know how to properly wire the wires I ask about below....
Here we go......
1) In the s13 KA RB swap guide: connect the white/purple to the WHITE by the KA fusebox...........
If the white/purple leads to the RB green ign relay (I think it does), what kind of wire is the WHITE one it connects to?? 12v keyed-2-start or 12v switched (ON with the accessories)??
2) Black/red = IGN power....const, switched, or only keyed-2-start??
3) White/black = ECU memory ....soooo....const right?? (ALWAYS 12v, even with key off??)
4) The white/red wire from the alternater.....where does that wire actually send it's signal on the 240sx....I need to know that so I can find the same destination on the pickup and connect the white/red alternator wire to the correct wire in the pickup.......THIS IS ONE OF MY MOST IMPORTANT QUESTIONS. (atleast the other ones I can guess at...I don't have a clue as to the purpose of this wire!!!!)
--TJ
pepegurr
Car: 89 coupe w/ rb20 swap - RIP but making a comeback
86 Porsche 944
92 FZR400 - Track Slut
95 240sx-se - Newest member of the family- DD
Maybe this can help a little.1) Needs to be connected to the ignition fuse in the outside relay box on a 240, should be simlar on a hardbody. It is switched power.2)switched power3)constant power4)not sure off the top of my head but ill go outside and take a look after it warms up a little.
s13_240_rb20
2) when you say switched, you mean that it stays on with the accessories, right? (not JUST when the starter is turning over?)
Thanks for looking at #4 for me!!
--TJ
s13_240_rb20
1) does this one ONLY get voltage when "keyed-2-start" and NOT when running? or is it one that stays powered while running...
--TJ
