perfect.. damn the weather isnt easing up at all.. i am in florida and its chilly as hellthe converted wrote:I'm actually planing on doing this to mine. If we have a day that breaks freezing up here I'll see what I can get done and take some pictures along the way.
i spliced both the + and - wire to the parking lights... but without the relay... everytime i try to run the fogs... it seems to be draining power from the parking lights.. i upgraded the fuse, but it still does it...danielekfuj wrote:splice a + wire from one of your parking lights, and wire it to a relay. Have the relay trn the fog lights on. simple in theory but can be time-consuming. correct me if i'm wrong.
yeh thats what i figured... aight thanks.. will try that...danielekfuj wrote:Most likely the wiring can't conduct enough current. Using a relay should solve your problems.
Thats exactly how I did mine with no problems. u just gotta remember to manually turn your fogs on and off. It looks a lot better with HID's in the fogs also.D_roc wrote:well i found this, that way the fogs can be switched on w/o the headlights dunno weather it wil help http://www.innerbean.com/housecor/fog_rewire.html
