mpbclutch33 »
https://forums.nicoclub.com/mpbclutch33-u89256.html
Wed Oct 29, 2008 2:15 am
So I e-mailed KP Technologies and this was their response.
"We got the module to work on the Altima coupe (as displayed on NICO) but the module does require some simple hardware substitutions. Because we manufacture our products in house we have the ability to make “Altima” specific modules at no additional cost – we just need to know about it when the order is placed so we can ship the correct product. If the product becomes popular we will add it as a stocked item with its own part number."
"Due to the fact the fog light relay is integrated in to the IPDM under the hood and is CAN bus controlled it is much harder to manipulate the system. Our module ties in to an OEM data bus to detect the position of the switch and then to control a separate relay to drive the fog lights.If you’re not worried about using the fog light button itself you can wire it up like your Pathfinder so the fog lights are on whenever your parking lights are on (with no control beyond that). However, it would still require quite a bit of splicing as you would have to tap in to both fog light control wires under the hood and in to the parking light signal with a weatherproof Bosch style relay. In fact, there is a thread on G35driver right now where we helped a sedan owner wire his fog lights up so they acted as Daytime Running Lights (on when car on, off when parking lights or headlights are on but still controllable by the switch). You do have control options, but unfortunately you will have to cut some OEM wires, add an additional weatherproof relay, and run the associated wiring under the hood."
If someone finds the thread on the G35 sight, please post it here.
