240hatchsx »
https://forums.nicoclub.com/240hatchsx-u176064.html
Tue May 03, 2011 2:15 am
I just dropped in a whole new cooling system setup in my 93 hatch and went with the Isis rad and dual fan setup works amazing in this FL heat down here and I cut into the factory wiring for the stock fan for the first fan so it would run normal and then just ran an inline fuse (25amp) for the second one and grounded to the frame so it runs nonstop while the key is on. Hope this helps
