Wiring electric fan
OldmanPurdy
Car: 2002 Nissan Altima SE 3.5
Hi all, Im in the process of rewiring my electric fan to run full time and after searching still have a couple questions.
(1) the relay im using has 4 posts 12v in (87), 12v out (30/51),12v switch 86), and ground (85). does the ground from the fan go to the relay ground(85) or do I have to ground both the fan and relay sepertely?(2) Do I have to use butt connectors when connecting the wire to the relay or can I solder them?(3) This might be kinda dumb but how do I connect the wire to battery in order to get the 12v in for the relay, do i just wrap it around the terminal?
thats all im kinda new to electronics so want to be sure before I start cutting wires. Thanks in advance!!!
e_c
Car: 1990 240sx
1. i believe they are seperate grounds2. you can solder the wires on3. look into how car audio wires are set up to the battery, you can get a dist. block that attached to the + terminal, or you can find a fuse that only has power when the car is on and just tap into that
OldmanPurdy
Thanks, my + battery terminal has a large red connector with some wires comming out of it so I guess that must be the distribution block. This is the final thing to do to the car, then once it stops snowing (yes its snowing ) I can take it out of the garage after 5 months of storage.......lousy winter!
onosqv
Car: '92 240sx Vert
OldmanPurdy wrote: Thanks, my + battery terminal has a large red connector with some wires comming out of it so I guess that must be the distribution block. This is the final thing to do to the car, then once it stops snowing (yes its snowing ) I can take it out of the garage after 5 months of storage.......lousy winter!
A distribution block for audio (as an example used earlier) is actually a separate unit. That isn't necessary for set up really.
If you are using stock battery terminals, replace them w/ some beefier ones, like from kragen/sears/whatnot. You can get ones that have extra outlets(holes) or ones w/ screws on them. Then you just crimp a ring terminal on one end of the wire and attach that to the battery terminal.
That's how I wired my elec fan.
And why do you want it to run full time? When I did that to mine, the car wouldn't warm up, HAHA (I also have alum radiator). I just got a hayden thermo switch from kragen, works most of the time (only pooped on me once, so I had to reset it - good thing it was cold out).
OldmanPurdy
Well I removed my clutch fan so I figured that the electrical fan would need to run full time to compensate, and it dosen't get too hot where I live even in the summer so overheating probally won't be a problem. (this is the little stock fan BTW) I will definatly get a better distrubition block, it will probally come in handy down the road anyways.
proimport17
Car: motocross, baseball
You have the pins wrong. Pin 30 is 12v in and 87 is power out to the fan. Yes you will need a ground for the relay and one for the fan motor.
