skswapman »
https://forums.nicoclub.com/skswapman-u9298.html
Tue Aug 26, 2003 8:42 am
I've got a '89 nissan 240sx and I'm in the middle of installing a red top sr20det. The harness was cut at the valve cover, and I have the SR's plug to the ECU... a couple wires are giving me trouble:
pin 105 = fuel pressure control module - red/white, I have no idea where i'm supposed to hook it up on the SR engine
pin 109 = reverse electrical flow return circuit (alternator fail input) - red, wtf where does this go? Main engine fuse box or what? pin 111 = turbo boost pressure control solenoid (overboost cut?) orange/black, again wtf. does this even need to be hooked up? pin 45 = ambient air temp sensor blue/white, This one puzzle's me It doesn't go to the MAFS....? whats an ambient air temp sensor? where is it anyone know? Also there's a 5th wire coming from the coil packs by the igniter but not into the igniter, if i remember right its blue with red, now is this a ground or a power wire? One more thing Do the grounds really matter, i mean if i hook up a sensor ground to an eccs ground that should be ok right as long as everything is grounded?
Someone please help... thanks in advance
