Silvia2b »
https://forums.nicoclub.com/silvia2b-u2470.html
Thu Dec 22, 2005 10:27 am
Sorry, subs can't be 2ohm stable, and amplifier may run stable with a 2ohm load from the subs voicecoil impedance however. So if your amp is capable, and you wish to do this, I don’t recommend it for most equipment due to the increase in heat production and reduction of sound quality.
However…. Wiring a sub or voice coil in parallel circuit will result in a load one half the amount of the total single impedance. For instance you have two subs (each are 4ohm SVC) you wire them in parallel, now you have a load of 2ohms the amp will see. The total output of the amp will be distributed evenly between the two subs. More than two coils gets a little complicated. I don’t want to introduce any formulas that I use, because most people just give me a confused look and say I make it more complicated that it is. That is how I do the calculations, with math.
If you wire in series circuit however then the total load will equal the sum of all voicecoils wired in line. For example 4ohm + 4ohm = 8ohm. Got it? O.k.There is also the possibility to wire in combination; for example (2) 4ohm DVC subs wired in series for the separate subs voicecoils, then wiring the two subs together in parallel. This would equal a 4ohm load total because; {(4+4=8)+ (4+4=8)}/4=4If you still want to do it check the owners manual for your equipment there will usually be a diagram similar to this from RF
CAUTION: Some or all of these wiring options may not be compatible with your amplifier due to low impedance loads. Please check your amplifier owner's manual to determine the best wiring option. Maintain proper polarity to prevent damage to your amplifier & woofer system. For easier readability, some diagrams have (+) & (-) terminals intentionally reversed!
