S12_hybrid »
https://forums.nicoclub.com/s12-hybrid-u41151.html
Tue Jun 13, 2006 1:10 pm
Alright, so im getting ready to drop my motor in (actually, drop my car ONTO).. But first I need to know what each and every connector is doing.
The lower engine harness has been cut, and I am not sure what these two connectors are for. I know that part of the loom contains things such as the reverse signal, speed signal, oil pressure, and oil temperature, and the start signal.. But why do these extra connectors exist that do not go back to the main engine harness? I have the suspicion that one of them may be the brake level sensor since it is on the right side of the engine (Japanese driver's side).
Any clues/hints as to what they may do. I am going to further peel back the tape and see if I can discover anything else.
Also, should there be an oil temperature sensor located to the right of the oil filter? Am I missing it? [that would blow chunks]
And finally, may as well kill two birds with one stone. The engine start signal, is it given via the ecu and pin #43?. This goes to the starter relay, yes?
And finally here are the pictures.
