wiring diagrams
fireheadmt
i know tons of people have asked for them, so i searched it. i got the actual diagrams from camel towing. (sr20det redtop in a s13)
i need these same diagrams with the wire colors labeled.and possibly the ecu pinout labels in english.
i know someone has to have it. please please help me out here im so anxious to figure out my sr problem
fireheadmt
bump
anyone have like the au service manual for the motor in the s13 at least
i cant even find it online anywhere to dl it. i really need it. english and wire colors.
xero1
Car: 08 Altima Coupe
i had the same problem, i founded out nissan only sold s13 with a sr20det in japan. they sold s13 with ca18det in australia. look for a s13 ca18det or a s14 service manual on ebay. all the s13 sr20det wire diagram that i saw were in japanese, i have never seen an orignal english s13 sr20det wire diagram.
xero1
what kind of problem do you have?
fireheadmt
i'm getting zero spark and zero fuel. which is making me suspect my ecu may be bad. (the motor has never run while in my posession, i just started to crank it three days ago).
i' know the pump is good because i can power it by sending power through the relay, which brings me to suspecting the ecu. but the only way i can figure it out is by understanding the ecu pinout, and checking to see if the ecu shoots ground back to me while cranking, if it doesnt, there is either a key ground missing for the ecu, the ecu is shot, or it's not getting all of the signals it needs to trigger everything else to work.
so my boss and i are trying to diag the problem, hes actually a nissan mastertech, but hes a pain and wont help until i get proper diagrams.
thank you guys, and i will try to find more info, my google searches are getting repetitive though..
so by chance do you have any of the diags?
FAST-DATSUN
Use wire "fuction" not color or you will get into trouble!
xero1
is there any signal going to the injectors?
mzdafrk
I have a diagram, I just haveto find it, I think you can go to Heavythrottle.com and look in their swap faq, it has a pinout, and description in english.
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
http://www.az240sx.org/tech/Pi...p.xls
thank adam on az240sx.org for this pinout he worked hard for itaka - omgthefog
240sxproblems
Car: 95 kat
I am having this same problem, and was wondering what would cause this.
