Just FYI, this is usually true but not always.Acecool wrote:Ground is ALWAYS BLACK in USDM cars
Ill see if I can find my audio system manual and give you the other colors..
Josh
I needed this myself, haha. Thanks man!the converted wrote:Is this what your looking for?
Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis (there is no ground in the harness you just need to ground to any peice of metal in the dash)Illumination Red/Blue Dimmer Red/Yellow Antenna Trigger Black/Red (only one you need to worry about)Front Speakers 4" x 6" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Translation to what they are on most aftermarket radiosConstant 12V+ YellowSwitched 12V+ RedGround BalckIllumination OrangeDimmer Antenna Trigger BlueFront Speakers 4" x 6" DoorsLeft Front (+) WhiteLeft Front (-) White/BlackRight Front (+) GrayRight Front (-) Gray/blackRear Speakers 6 1/2" Rear DeckLeft Rear (+) GreenLeft Rear (-) Green/BlackRight Rear (+) VioletRight Rear (-) Violet/Blacksilpena wrote:i've used that diagram before i'm just too retarded to know what each means like constant and stuff on the antenna plus i'm partially color blind so know blue to violent is kinda hard for me.
