Wiring Diagram for Axillary Switches with a pic of the new lights.
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
So I didn't want to screw up my Aux light install and created a simple wiring diagram. before I did anything. This applies to anything that you want to wire to a switch(es). FYI the other pics are from my iPhone so quality is s***.
Billy
slickroger
Car: 2001 Nissan Pathfinder
where are the backlights that are in your diagram no pics?
Pwnin O'Brien
slickroger wrote:where are the backlights that are in your diagram no pics?
^ What he said. Take some more pics of the front aux lamps too.
Empty V
I'm still waiting for them. I ordered 2x 28 LED lights and if they work out I'll install a total of 4. Wires are all run and ready to go.
I dropped the headliner and drilled holes in the roof for the wires. I installed rubber grommets between the metal and power wires so they don't strip and then sealed them with "seal-all" to prevent leaks. While I had the headliner down I opened up a can of worms and reupholstered it black. I also painted the 2 dome light housings, map light/temp gage setup, a-pillars, the vertical handles and I'm finishing up the reupholstering of the sun visors. I left the horizontal handles gray for a bit of contrast and I really dig it. Pics will be up once I finish the sun visors.
EDIT: I also just installed a matching handle on the driver's side, I still can't figure out why know why they don't have on there.
Billy
Modified by Empty V at 4:27 PM 11/25/2009
Natedogg1701
Car: 2003 Nissan Pathfinder SE
dam sounds like you went to town on your Q, id like to see some pics of the interior once your finished with it.
and just a lil tid bit of info, (not knocking how you wired your lights, this is just how i was taught) whenever i wire lights or anything thats drawing power, one if possible i prefer to use relays, or if im using a switch to switch the full power supply to the load, i switch the ground side of the circuit, i see people switch the power side and it causes the switch to heat up and burn out,my buddy burnt out 3 switched for his fogs before he rewired them and switched the ground. from what i know, giving constant power to the load and switching the ground end up in less current flowing through the switch, obv because the load is not only using power its resisting it too, so with the switch having less current flowing through it it heats up less and is less likely to burn out.
again im not ragging on your set up or your methods, u've already proven you know what your doing when it comes to car electronics, i just figured id throw that info out there, and im curious what your opinion is, on my opinion. again nice set up.
Empty V
The last few things I wired from scratch were applications where the battery gets disconnected when not in use. So that was my mindset, I never considered how the switch could wear out if constantly fed voltage. Chalk it up to a lack of knowledge. If wiring the ground to be cutoff is a better way to go then I will definitely switch it. Here's some pics of a project I'm re-doing with a higher res LED backlit(lower power consumption) LCD module, it's for a underwater video housing. It's amazing what you can do with the right tools.
Natedogg1701
thats is actually very cool, nice idea man. what is it exactly you do for a living? it seems like u know quite a bit about quite a few topics, what are you a renaissance man or something? lol
alexf20c
Car: '00 SE 4x4
renaissance man...? that switches the hot side and does not use relays. hmmm...........
Pwnin O'Brien
alexf20c wrote:renaissance man...? that switches the hot side and does not use relays. hmmm...........
Why do you always have some douchebag response? It's almost as if you search out posts to which you can reply with some a**hole response in an attempt to ruin someones day. Instead of that condescending reply, you could have given him a helpful pointer or not respond at all. Also, you only re-posted what Natedogg1701 posted, which really is not helping anybody.
alexf20c
Car: '00 SE 4x4
it's funny because you recommend that i give a "helpful pointer or not respond at all," yet your own post doesn't help anybody here either. and oddly enough, yours is a douche bag response as well.
ah, the irony.
Pwnin O'Brien
alexf20c wrote:it's funny because you recommend that i give a "helpful pointer or not respond at all," yet your own post doesn't help anybody here either. and oddly enough, yours is a douche bag response as well.
ah, the irony.
It was meant to help you.
Empty V
Natedogg1701 wrote:thats is actually very cool, nice idea man. what is it exactly you do for a living? it seems like u know quite a bit about quite a few topics, what are you a renaissance man or something? lol
Well I do have a few different gigs. My main one is designing and building massive VideoWalls like the one below, sorry for the poor iPhone pic. My "fun" job is working in film as a producer/director/post production guy. I SCUBA dive for fun and already had pro camera gear so I figured I'd buy a housing for it and modify/improve it.
Billy
Empty V
Empty V
There is no helping him. For some reason he's a bitter ***hole that likes putting people down. I'm guessing either he was dropped as a child, teased a lot, or his mom drank while she was pregnant. I'm sure one of those 3 is a winner.
Billy
Modified by Empty V at 1:26 PM 12/2/2009
slickroger
Empty V wrote:
LOL
Billy
All of the above
Billy
What is the biggest video wall you have done. your jobs/gigs are sweet its hard to find something you actually enjoy doing and have someone pay you for it.
Empty V
The biggest wall I've done was a 16 cube wall (8x2) @ Hawaiian Telcom in Honolulu, HI which included 3 LCD touchpanels that controlled the Cubes(rear projection displays, kinf o like TV's), VideoWall layouts, and the massive 5 zone 28 speaker distributed audio system. We also built an amazing conference room for them that had it's own touchpanel control system with audio and displays. The 12 cube wall in the pic I did a few months ago for Comcast Cable in Atlanta, GA and I'm in the process of designing another one for another branch on the East Coast. We started off as a furniture company which we still build and that's why we've got the CnC router plus lots of other cool machinery like vacuum formers.
Billy
Natedogg1701
that video wall is cool, and i thought my plasma tv was something special. lol.
pwnin dont waste your breath, hes as person who..."gets off on, gettin on other people, no ****" quote unquote Dwayne Michael Carter, aka Lil Wayne. and if you read 99% of this guys posts that phrase i put holds true
and alexf20c, y do do you insist in stirring up shyt? its people like you who deserve to get rotten shyt luck your whole life because your just such a pompus arrogant d!ck, or you are one because your life has fed you shyt. either way just grow the hell up and in a way of repeating pwnin, unless you have something nice or helpful to say then dont say anything, or in other words, just shut the FU*K up dude.
naladude911
How did you get the wires from the switches all the way to the roof and to the back?
Empty V
naladude911 wrote:How did you get the wires from the switches all the way to the roof and to the back?
A-Pillars
Billy
Empty V
Well the other day I realized why I wired them the way I did. It's because I believe that the LED's in the switches wouldn't light up if wired with the ground as the cut off. Does that make sense?
Well I got the rear lights up last night and took some pics of the whole setup. I'll try to take some night shots to show how much light is being output. The front HID's are insanely bright and the rear lights really output a good amount and are perfect if someone is tailgating me. They came in chrome plastic housings so I took them apart and painted them but no biggie.
korbeano89
Car: 1997 Infiniti QX4
look great, good job man. where and how much was the basket you got?
KyooX4
Car: 2001 Infiniti QX4 4wd
Man... your truck is looking freakin sharp!
Empty V
korbeano89 wrote:look great, good job man. where and how much was the basket you got?
Thanks! I got the safari basket from a dude that used to have a shop and now sells from his house. If you call Surco(manufacturer) and ask for 5 Start Auto in LA that's who I bought it from. If you do get one don't buy light mounts from them, I had some custom ones fabbed up that are much better, lighter, and cheaper then theirs.
Billy
Empty V
KyooX4 wrote:Man... your truck is looking freakin sharp!
Thanks, it's been a long road and I'm far from the end. Here are a few night pics so you can see how bright the lights really are. I kept the exposure the same on the comparison pics on the wall so you can tell the difference between the headlights/running lights and the new lights. Keep in mind none of them have been positioned for optimal output yet.
Stock Headlights Only
Headlights with Axillary Lights
With Running Lights
Without Running Lights
Pwnin O'Brien
I really like that pic, your truck looks really good! I think your next big purchase should be wheels and tires, that will make it look like a whole new truck.
Empty V
Pwnin O’Brien wrote:I really like that pic, your truck looks really good! I think your next big purchase should be wheels and tires, that will make it look like a whole new truck.
Thanks Pwnin. It hasn't been washed in weeks and I'm somewhat embarrassed but money has been tight. I ordered a set of wheels but they've been backordered for 6 months. I decided to go to a new reseller yesterday and I'm supposed to get pricing and ETA today. A few weeks ago at a Supercar Sunday/Toys for Tots drive I saw a truck that had my rims. Waddaya think? 17x9's
