sweetrm125 wrote:Where do the dash speakers meet up with the front because if possible i'd like to amp the dash speakers seperately so that I can utilize the "center" channel on my multi processor because as it stands the audio is not decoding corectly. I should be able to bridge the 2 speakers right? I'm not sure if i can do that i'd like to send the center channel data to both dash speakers but technically there should only be one speaker to have 5.1. Anyone have any insight on that?
True 5.1 is Front L & R, Rear L& R, Center and sub.
If you have the Bose, the front tweeters and door speakers do not meet up
If you don't have the Bose, the dash 3.5 and door 6.5 meet up at the junction of the door and footwell area it will all be wrapped in black tape with other wire though ( I believe, check the FSM by going to the page, and right clicking the AV file, then hit "save target as", and it'll download the FSM instead of trying to open it through the internet!)
What you are proposing is a bad idea. center channel output is not designed to be spread out over the front two channels... if you have a true 5.1 decoder, the end result will be sloppy! This is especially true since your door speakers are 6.5 mid bass speakers, and your dash speakers are tweeters... the center channel sound is not full range, and will only be bits and pieces of musical information... so essentially, since you dontt have full range speakers in the doors, your system may sound like crap...
If you are intent ton doing this, I would replace your door speakers with a component setup.. that way you will have your highs with the tweeters and your midbass from the 6.5's, and you can spread your center channel over the two dash speakers.
WHen you do listen to movies in 5.1 surround sound, the voices will come through the center channel, with sound effects and background noise coming through the other speakers! Hope this helps and good luck!
