ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Sat Dec 18, 2010 1:55 pm
Watts a measurement of true power can be easily converted to amps using the formula
W =V x I or watts = Volts x Current
The lamps you will use have a wattage rating at a nominal voltage of 12 Vdc
EG Say your light bulbs add up to 60 W @ 12 V, 12 is the nominal range of a 12 V system that actually ranges from 10-15 VDC.
Using W = V x I. Plug in the known values. 60 = 12 x X, you do not know I or amps, thus X
X = 60/12
X = 5
So at a nominal range of 12 V your lights draw 12 Amps.
So if your using a relay it must have a load carrying capacity of at least 5 A.
That means the contacts must be able to handle at the very least 5 A at 12V, but the coil of the relay will be what it is and there lies the quality of the relay. A quality relay can handle the nominal ratings of what you want, but being able to handle more is good. The relay should be rugged enough for vibrations, solid for higher voltages and enclosed.
If this is my car, I would only use name brand relays that are certified by: CSA, CE, DIN,UL,UL-Can, SAE or others. Stay away from cheap crap and be sure to properly fuse your branch circuits.
All your parts are available at auto parts stores, but all electrical parts are not created equal. You may pay more for quality parts, but cheap crap is too expensive, because when it fails or burns up you will lose your time and effort but what about your car and life.
Be smart, be safe, learn before doing if you do not know. Electrical failures can be deadly.
