compactfean wrote:im not sure how much voltage the tm wire puts out. I do know that if you ground the single prong cts your gauge should go to full hot. If it does than the gauge and wiring is fine. .
I did test it and it does max out when grounded so it should be good,its getting power ... I think it was 8. ? volts. Im not too skilled as far as elec. theory. I figured that if i put the 12v (ign. on) power to the TM it would start working..lol, that didn't do the trick, so......
Its getting power, I gave it more power, the sensor is new, the gauge works, ( thinking)
