AznRide »
https://forums.nicoclub.com/aznride-u2577.html
Tue Jun 24, 2003 4:43 pm
What plugs did you cut off? Cause I followed the guide too and I finished my wiring in like an hour. I cut the female end plugs by the SR S13 fuse box, then I plugged it into the F8 and F10 on the SR ECU harness, and connect the F2, F3 wires to the end of the female plugs that I just cut off of the S13 fuse box.
If you didn't do what I did, you just wired to the male ends of the S13 ECU harness, which you have the male ends not plugged into anything. Either way, it should work, but my way looks better.
1. Now, I have tons of extra wires, which I think will not be hooked up, right?
2. On the SR engine harness, by the alternator, I see a black cap, which I think goes in to the alternator, right? If so, under my KA fuse box, there is a red cap and I think goes into the alternator, so now i have 2 connections to the alternator? What do I do?
Rather than that, my car should start up fine right? Are you having the same experience as me?
