HEY! I have a protoboard and my mom says I'm cool.Qxxx4 wrote:Best bet is to get a protoboard and test your circuits there first, but if your not a big electronics nerd like me then im sure you dont have that stuff lol
From my professional opinion as a mod on NICO, I think you're coolbmlawless wrote:HEY! I have a protoboard and my mom says I'm cool.
ahh yeah that is true. . I'm not a 100% noob, I actually worked in Radio Shack and screwed around with parts I'd "borrow" from that job. . But I'm def. not an electrical engineer. The light I got is actually a 168 wedge bulb -- I figured it would be cleaner to wire, since the resistor is contained in the base. I can then add another resistor or pot to control the light if it ends up being too bright and ricey. There'll just be a single light, because I'm NOT a pro at this, and there def. would be fire if I tried to add two.Qxxx4 wrote:rule of thumb, most LED's have a longer leg, that longer leg is the negative end. Make sure you test the LED, supervise it for a long period of time to make sure the resistance doesnt get hot and melt things! Best bet is to get a protoboard and test your circuits there first, but if your not a big electronics nerd like me then im sure you dont have that stuff lol If your doing multiple LED's be very careful of your choice of connecting resistors in parallel or series. If your putting this in your car you definately dont want to see smoke coming from the circuit at 100km/h on the highway....yikesssss
good luck, and ps....LOVE the signiture pic
Just an ambient light that shines down on the console, like you'd find in some other cars. I sort of like the utility at night, but I also like how it looks. I was scared of it winding up ricey, but it aside from the bit of glare I have on the rearview, it looks stock. The glare isn't bothersome however, just used a wide-angle LED. The LED is flat and sits almost flush (it's actually made up of several tiny LEDs -- see pic).AlabamaDan wrote:So what exactly are you doing with the leds? I'd like to wire up a series of leds in the engine compartment for work lights. Anyone ever thought of that before?
Def helps, and I'm gonna buy a proto board. . part of the reason I did this at all is because I love d!ck' around with stuff, and learning about electronics. My QX4 is my protoboard. . hahamaik21 wrote:for leds u can run a 220ohms 1/2 watt resistor from radioshack, it will work with ultra, super or normal bright leds.
[mg]http://img339.imageshack.us/img339/4703/ledscm0.jpg[/img]
i made this some days ago . theyre 40 super bright red leds.
if u had a protoboard, do this:
+12 volts ---- resistor 220ohms -------- ( led ) ----- ground
u can conect the led in the inverse polarity and if u do that, it wont bright.and if u do right, it will bright.
leds can damage if u dont use the right resistor. if the resistor is to low led will burn and if is to hight led wont bright .
maybe all this help u
Yeah the 2nd image is what I'd be using. . the 1st one depicts a state when the LED would be in the off position during darkness, the 2nd is the opposite of that. These depictions are identical to what I have wired and have working now, minus the photoresistor. I just need to add that, and in the correct resistance range -- but that part, I have NO clue how to determine. I'm trying to find specs on OEM auto-on headlight sensors, but to no avail.maik21 wrote:
for the first image, R2 will be a led with a resistor as a package.
(+) ----photoresistor ---- resistor ---- led ----- (-)
with the second its the same thing.... R1 will be a resistor with a led as a package....
it will work, but u need to know whats the resistance in dark and whats in light because this is very important in the operation of led.... u can change 1kohm resistance shown in pic for a 220ohms resistance.
You're awesome!! Thanks -- I'll go pick some up and try it out. . It's interesting, because I'm worried about it not working right the first time, yet I spent the time taking it all apart and figuring this much of it out.maik21 wrote:photoresistores are cheap.. go to radioshack an buy some one. i understand now ur picture diagram ....dont replace what i told u replace because i had misinformation .... but after the v line, yea, u will need a resistor with a led. so go and get the photoresistor... there are 2 types... one that has high resistance in dark and the other is the opposite. if u dont have a multimeter u will need to do two configurations u found to know what will work . dont worry, u can burn nothing.
