onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Jul 01, 2005 1:49 pm
Well, there are a variety at summit. One type goes on teh radiator fins - delayed temp reading, not as accurate, but easier to do.
The other type goes in the coolant stream, much more accurate, but slightly more pita.
I have the one on the fins - hayden has instructions, as i'm sure every other kit does as well.
The a/c fan turns on when you turn on the a/c & "I think" when the car starts hitting a ridiculous temperature -> not sure on that last one nor the actual temperature (mayber 215 degrees or so?).
Easier to run a dual relay setup.
