mine had this http://www.caraudioandelectron...i.htm connected to both rear speakers somewhere under the black plastic cap (it's dark and they're screwed on so i can't tell you exactly where right now) and this
http://www.sounddomain.com/sku/PERLVT2 (looks like that, red light on one end and 3 wires on the other) hooked up behind the headunit (not sure which wires, but i could find out if necessary) so the amp would turn on and off with the headunit. the shop that installed everything even had the great idea to zip tie the speaker wires to the hard fuel lines.
3 1000w 12's with 1 1000w amp, it hit HARD, even when turned down. ever seen the top of your trunk lid visibly move up and down with the bass?
i took it all out and found that i'm happy with the bass that stock bose provides, now i can't even give this stuff away, but it is Rockford Fosgate so i guess that's the reason.
i love using the () :fruit
