Wiring Altima electric fan into S13
JG180SX
Car: RHS13
Does anyone know how to wire up some Altima electric fans on a S13 chassis? Anyone do a write up on this? well if anyone has some info post it up for me. I took off my old clutch fan because the clutch broke. I've been driving around with no fan on. I know not smart but its been cold. Thanks
240sxOwner
Car: 93 240sx
I just put a pair of altima fans in my s13. I heard they were basically bolt-in...someone lied, or i was sent the wrong fans.....But i made them work. I had to use my dremel quite a bit. There are four wires going out from each fan motor. The power wire is yellow/white for one, and blue/white on the other. I just ran the two wires and butted them together, then ran a 14g wires from the other end of the connector to the fuel pump fuse (for now). Then i did the same with the ground wires and put them on a ring terminal to the headlight motor. You can test to see which wire is power and ground by hooking up wires straight to the battery to the fan motor.....then just tape the other two wires up. I will take som pics and show you how mine came out....Hope you have a dremel!!
Modified by 240sxOwner at 1:55 PM 2/15/2006
240sxOwner
Car: 93 240sx
The first is a picture of how i wired them....I took two wires into one..then ran the one to the fuel pump fuse...and other wire to headlight ground....Hope this helps
