19b wrote:Question, can the rev limiter be raised? I think you can remove it all together, am I wrong? What rpm are they actually set at? How stupid would it be to raise it? I don't want to remove it, it does serve a purpose. All opinions welcome.
Well, for starters, the KA has serious harmonics problems right around 7000 RPM. While you could balance the crankshaft and raise the rev limiter, you'll still have to deal with the KA's abnormally long 96mm stroke. At 7000 RPM, the piston speeds are faster than 3800ft/min. Assuming 4000ft/min is "safe," how fast do you really want to go? Moreover, the stock KA24DE starts running out of breath after about 6000 RPM. If you were to redesign the intake manifold, drop in some wild cams, and port and polish the head, you might see some power open up past 6500 RPM.
So, yes, it's feasible, but you're talking about a balanced crankshaft, lighter and forged engine internals, crazy cams, forged/titanium everything on the valvetrain, port and polish job, and a redesigned intake manifold, possibly even ITBs. Guys have installed ITBs on their KAs, and frankly, it damn impressive. Check out the NA KA forums and see what some of those folks have been able to pull off.
Hope this helps.
