Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Mon Jun 14, 2004 10:33 am
Ok, I found a mistake. On the "O" plug, the "h" wire does NOT go to the IGN relay! It goes to the ECCS relay, the injectors, and the ECU backup power pin 58. I corrected this mistake.
The corrected wiring guide is here.
Since there only seems to be confusion about what to do with the h wire, I will only discuss that wire, calling it O(h).
On the RB20 harness, the plug O(h) wire splits into several wires that go to the injectors, the ECCS relay, and to the ECU pin 58. All you have to do is find the wire going to pin 58, cut it, and connect it to F3(17). Then you can just connect everything else on O(h) to F3(1).
