fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Mon Feb 07, 2005 10:51 am
There arent that many wires, but yes I will help since this is my original post and I am re-doing it anyways heh since my box was bad (ebay...)
Thick red and black are the battery positive and negative. Obviously you should have +12v on the red one, and a good ground on the other one.
White wire is the trigger wire. This connects to the green/black stripe wire that can be found in your coil harness.
The thin red wire needs a switched +12v that is only on when the ignition is on. This can also be found in the coil harness-- the wire you want is black with a red stripe.
Orange and thin black are the coil wires. They go to the positive and negative (orange +, black -) on the coil.
The magnetic pickup thing on the other side of the box is not used.
Its really not that bad of a setup at all. I'm sure the BTM is very similar since it must receive the same type of power wires and will need the trigger wire and coil wires as well. There is probably (although I'm not sure) just an additional port for a vaccum source.
If you have any problems feel free to ask!
