need some help here . searched everywhere. looked up FSM
im not getting power to the int. fuse/relay box
sr20det swap, s14 red wc to a 69 datsunfairlady2000,
jdm main harness with oG jdm gge stock cluster stock ECU,
JDMstock s14 Main harness: removed de-pinned for almost everything { ac,wipers, seats,climate,smart cont. unit, abs,doors mirrors, SMJ }
so both fuse boxes de-boxed and guts are side by in the dash.
I found this pic online... s14 int. harness power supply the guys was having the same power supply to int. fuse box issues i have.
http://img829.imageshack.us/img829/3072/488ed6e2.jpg
from the eng fuse box i have one white/blue wire that was cut 75 amp fused and the interior fuse box has bare copper connections on the back ...where a plug would go.
http://imageshack.us/a/img835/2382/img2 ... 254924.jpg
http://imageshack.us/a/img850/2405/img2 ... 232759.jpg
i only have one big wire, white wire with the blue stripe coming from the big fuse box (75 amp fused). it looks like the picture shows it plugs into my fuse box . but the Plug has 2 wires ???? help i only have one wire that was cut off, the second wire in the plug looks to have a blue stripe too, do i just double the 75 amp leg and hook to both of the big connections ???
I also the quad plug in the picture...
any body know what the wires are for?
i have the smaller white wire with green stripe to be hooked up too, (45 amp from big fuse box ), i see this would lead to the quad plug shown in the picture,
http://imageshack.us/a/img41/9872/img20 ... 352958.jpg
any body know what the other 4 wires are in the quad plug ??
any help is really appreciated
Roulette77
