Wiring a AEM Uego into the stock RB harness
streeteg
I picked up a Uego this weekend and am looking to use the sensor not only to monitor my AFRs but in place of my stock sensor as well... At least until I get tuned and rid of that thing all together. I read the directions and it doesnt seem to have an output for the 0-1v narrowband that goes into the harness- But I have heard of people doing this--- Is it a possibility?
Further--- I have a Power FC that I will be loading a basemap and a Z32 Maf from now...but I am a total rookie at that type of stuff--So I think I could technically bypass the stock 02 as well.... BUt i dont want to get ahead of myself...
-Eric
Carl H
uego does not have a 0-1v narrowband output...the 0-5v output that it DOES have will fry the ecu's o2 sensor input and operates a completely different way.
Joe
in other words
you cannot use a AEM unit on your factory computer or you will burn it up. the AEM UEGO is designed to be used a standalone sensor, or with an ECU designed for wideband inputs.
robbie2883
Car: 1998 RB25 Kouki
if you want to tie it into the factory ecu you will need to get something like an innovate wideband which has programmable outputs
streeteg
Thank you gentlemen...That idea is out of the window.
