Wireing woes
Paulpen
Car: Nissan Onevia with RB25
Basically after decluttering the whole car loom for the RB25 onevia (RHD UK spec S13) im in a tad of a pickle with a few circuits
These being the fuel pump and heater
Ive done quite a bit of work on the fuel pump issue so here goes.
The pump is good as 12v across it makes it work.The pump to engine bay wiring is good.The fuel pump relay works when teted but wont when in normal setup.In normal setup the relay has 12v at 3 pins but not the one to the pump.2 of those wires are black/white and are therefore 12v so are correct.The other wire is black with a pink trace that goes from the fuse box through connector F10 to the ECU. Am I right in thinking this should be a switched ground and not 12v ?
As for the heater issue here goes.The fan works fine on all different speeds however I can get the recuirc flap or any of the different vent direction flaps to move. Also the lights above the vent positions do not light up.
Anyone had this issue before and would it be something to do with me removing all of the air con wiring ?
