carbonkid »
https://forums.nicoclub.com/carbonkid-u34683.html
Fri Mar 13, 2009 2:06 am
I searched and have found nothing on this is the sr forum. Im running Msd 72lb low imp injectors. Ok here it goes, i got the resistors and msd clips from jgy. I solder them in correctly, resistor in the thiner wire(colored wires, not the red) in every injector just like Jgy told me to. I also wired in my n62 maf, following the diagram i found on nico. Car cranks over and wont start, took the injectors out to see if they are fireing and they are not. Called Jgy they told me they only heard of that happening one other time, they were running msd injectors on a power fc and they wouldnt fire, same like me. They told me to call apexi, maybe they would know. But they never heard of that happening, and there were no special settings on the fc to "fix" it. So i called msd, they told me how to check to see if the injectors work and they did.
So im at this point. Injectors work, there low imp so i need resistors, i got fuel coming into the rail, fuel pump is turning on, i went over the harness like 10 times to see if i left something unpluged or wired something incorrectly but no. Anyone ever have a problem like this? I about to try a stock computer out.
