Wired in my Stereo and .... no sound....
jmcyan
Car: 1995 240sx
Well tonight i finished with my pads, all around, pain with the back cylinders, on my 95 sx .... Went to go put in my sony stereo (never had an issue wireing in a head unit at all before) Everything turns on fine... (someone installed a 6-disc, but i disconneted most all the wires for it short of the ant. module)and there is no sound at all comming from the speakers.
I have a soche wireing adapter and its all correct. (im not using the Solid black on 1 of the 4 connections, and I have the blue with a white stripe not connected (amp remote) but i tried to connect it to the stock wireing harness to see if that was it, with no luck.
After all was connected and turned on... im still haveing the same issue, no sound... there are 2 extra clips (black clip with a red wire, and a white clip with 3 or 4 lines from it.. that wasnt conneted to anyhting when i pulled the stock unit that wasnt working...
Anyone who has any ideas or help would be appreciated... If i didnt explain too well please ask more and i will elaborate and see if i can explain it a little better...Im beating myself up over this one...
Thankyou..
yangs13
Car: 1993 240sx-Dead, 2001 Maxima
you didn't hook up the amp wire
mr2lickit
Car: looking
Lucky for you install Doctor will answer all your stereo questions. Heres the link for 240's and just load the PDF. file.
http://www.installdr.com/Insta....html
Good look and I reccomend you bookmark that site. ITs really good stuff.
jmcyan
Car: 1995 240sx
my stock amp is dead, and i need some help on where to locate it so i can bypass it or rewire everything..can some one please tell me where the stock amp is, and or the best way to bypass it? thank you
Rex
Car: None
jmcyan wrote:my stock amp is dead, and i need some help on where to locate it so i can bypass it or rewire everything..can some one please tell me where the stock amp is, and or the best way to bypass it? thank you
S13 or S14?
Either way look herehttp://forums.nicoclub.com/zerothread/115587
jmcyan
Car: 1995 240sx
i appreciate the info....but i am still having problems finding the stock amp....
ricebike
2002 Quest
2005 Altima
if you look @ one of the links Rex posted for your s14 (1995),as seen on here
Quote »The ’95+ SE (as well as other Nissan/Infiniti models of the same era) uses a system with remote mounted amps – in this case, under the rear package shelf. [/quote]
SR20drftSX
Car: 240 hatch(sold) , 92 Infiniti G20 JDM Sr20
same thing happend wit mine except the cd player wouldn't even turn on..and i ran ajumper from the stereo directly to the battery and check each terminal sepperately and still no turn on..i think i need a new cd player..dk tho..
Camel
Car: That would be obvious....
You probably need to bypass the stock amplifier hanging under the rear deck. Look for a plastic box and check the wires.
Chadd
