I was wondering if anyone else has gone down the same road I'm about to try with my Versa stereo:The Versa S (not SL) stero has no auxiliary jack and therefore there is no immediate way to play music from ipods, mp3 players, etc.While there are a few options on how to work around this, I'm thinking about hooking in a wired FM modulator. This allows you to pick up your portable device output over the FM radio. This is not to be confused with a wireLESS FM modulator which involves much greater harmonic sacrifices.I've read from some sources that installing a wired FM modulator involves almost as much work as installing a new stereo. Another source said that they installed in 15 minutes. I thought before I went ahead and potentially made a mess, I'd better ask if anyone else has successfully done this.The FM Modulator I'm looking at is:
http://www.circuitcity.com/ssm...il.do
and the install schematic is:
http://www.audiovox.com/manuals/owners/1286818.pdf
though any general advice would be greatly appreciated.
Thanks.
