Wire Up My Starter
tunedis95
i replaced my started and it still just clicks when i try to crank her up...so now i think it is somewhere in my wiring harness that is faulty....can i wire starter to switch to battery.......please let me know this problem is getting on my nerves.......
thanxeric
hachibroku
Car: 98 240sx s14 MO Betta
i did it on my corolla i ran the power wire strait from the battery and it worked just fine.
Nismo_Freak
Car: 89 Nissan 240SX
There are two wires on the starter.
Major wire = 12V power2nd wire = Switchable ground
Make sure both are still connected, if they are then you need to try hitting the starter with a hammer (yes, believe me on this).
If that starts the car then you need to go and get another starter as the one you got will continue to give you that same problem.
tunedis95
so the big wire that is screwed tight is the positive.....wire that one to my battery....the other skinny one ground it through a switch right
tunedis95
can ya label the wires (ground, Relay,Posotive) from a picture please
PHOTOSHOP or something
PLEASE
Nismo_Freak
tunedis95 wrote:can ya label the wires (ground, Relay,Posotive) from a picture please
PLEASE
There are only two wires, one is thick and has a ring clamped onto the end of it. That is the power lead from the battery and it goes onto the big stud that is sticking out of the alternator motor.
Right next to that should be a small 5mm tall "pin" or another bolt down stud. That is where the signal goes which is the thin wire in the wiring harness.
