Wire tuck help
240 Hatch_Derek
Car: 1991 240sx hatch
Im in the process of gutting my 240 and was wondering what is the best way to tuck all the wires on the inside of the car? I plan on painting it and making it look cleaner and need that stuff out of the way. any help would be nice.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Pull the entire harness from the engine bay, and engine harness. (you will probably want to start at the smj) and label everything that gets unplugged. Then go through the entire harness and separate what needs to go out and what stays in. when you pull the harness, mark the section where everything will go back inside the car (fore future reference). Once everything is pulled out of the harness that will stay, start routing where the wires will go using the section you marked as a length guideline. Then shorten/lengthen what needs to be and then wrap and install. Quality wire tucks I've seen a good 40 to 60 hrs put into it but looks so damn good when done right!
Sideways570
Where you located at I got a buddy that does them in pa. Pm me and let me know where you are located.
