RYNO_s13 »
https://forums.nicoclub.com/ryno-s13-u3194.html
Thu Jan 16, 2003 6:48 pm
If you're running a battery from the rear, I cannot stress enough to get BATTERY cable, NOT welding wire. LatMo is right, it's not so much more battery, because you still have the whole volt/ohm=amps thing so the extra batt won't make a noticeable difference. That of course depends on whether you wire in series or parallel. Also, you can check your wiring, your problem may be there. If you're looking for the extra amperage for accesories, stereo, etc, consider running an additional alternator solely for what you're running. there will be a bit of parasitic power loss, but in reality it's not much.
