wire question
srt4monster
ok so i have this Blue wire with a red stripe coming off the engine harness of my ca18det. it has power to it. im just wondering where this side is suppose to go. i thing the other side goes to the coils??? and help would be great.
Noxy
Car: 1993 Nissan 240SX
1992 NX2000
2004 Sentra Spec V
Pulled out my spare harness to check for you, but it's not connected on mine either...
I'm pretty sure that wire gets connected to the main ignition power with another thick wire, but I can't remember which.
Edit: Yup just checked the wiring info. Here's the link it's about 3/4 down.
http://web.archive.org/web/200705131750 ... p#removeka
float_6969
Yea, it connects with a large black w/ red wire.
srt4monster
float_6969 wrote:Yea, it connects with a large black w/ red wire.
i have the blue wire with the red stripe connected to the large black wire with red stripe but thats at the plug. this part of the wire is just hanging out by the ecu connector, and it also runs to the coils. im just wondering where the hell this part of the wire goes.
float_6969
oohh, I thought you were on the other end of the harness. If it goes to the coils directly, the it SHOULD be connected to the ignition relay, which should be built into the wiring. I don't think that wire goes anywhere near the ECU plug. maybe it goes to the ignitor? Ur harness sounds like it's hacked up pretty badly.
srt4monster
float_6969 wrote:oohh, I thought you were on the other end of the harness. If it goes to the coils directly, the it SHOULD be connected to the ignition relay, which should be built into the wiring. I don't think that wire goes anywhere near the ECU plug. maybe it goes to the ignitor? Ur harness sounds like it's hacked up pretty badly.
see thats what i thought but i bought a brand new harness that was uncut and its in the same spot.
Noxy
1992 NX2000
2004 Sentra Spec V
One of my harnesses is like that, too... Maybe there's an evil importer chopping these wires before he sends them? Just a theory...
srt4monster
Noxy wrote:One of my harnesses is like that, too... Maybe there's an evil importer chopping these wires before he sends them? Just a theory...
lol that would suck. ok so where does this wire do on your other harness?
Noxy
1992 NX2000
2004 Sentra Spec V
Swap wise I have mine connected to the the Black/Red thick wire. Just wondering, but did you hook up thin blue/red and thick black/red?
srt4monster
Noxy wrote:Swap wise I have mine connected to the the Black/Red thick wire. Just wondering, but did you hook up thin blue/red and thick black/red?
nope i cut off the ca plug and connected the thick blue/ red wire to the thick black/red wire. also i tested the wire and its the same one the goes to the coils and to the plug i cut that i has all the wires i need for the swap. so this wire goes three ways. it also has 12 volts running though it.
