wire layout to the BCM
tbgreen21
Car: 2006 infiniti m35
what are the colors and wire locations for the 3 connectors that plug into the BCM . And I mean the individual wire collors not just the black and white plug ins. My BCM was kicked free and the wires seperated.
Q451990
Wow... gotta keep the wife/girlfriend/goat under control!
It's in here somewhere.
Good luck!
Heath
tbgreen21
Thanks ,but Isearched this layout already and the color coded layout is not there. A general layout that rrefers to only the three pugs as M1, M2, M3 are represented. I need the actual wire by wire and position they go into each plugs slot. I could figure this out if I had a color picture of the three plugs in another BCM or a color coded wire schematic for each plug. But this the link you provided does not have either. STILL NEED HELP! Can someone who owns a m35 please post a high grade picture of the plugs in the BCM? Ill post my picture of the wire problem.
Q451990
I agree that a good picture would be your best option. If you don't get that, it looks like you can go to the individual systems that the BCM controls (outlined on BCS-7) and find diagrams there that are color coded and reference the pin positions you see on PG-104.
For example, you can go to page BL-69 and see the color coded wires labeled by their pin number for the intelligent key system.
I sure hope all of the wires aren't disconnected!
Heath
