Broadfield »
https://forums.nicoclub.com/broadfield-u46569.html
Sun Mar 07, 2010 7:20 am
Since I do this type of stuff for a living, and for ages at that, I have a little different perspective then most. The reason I see a lot of people using dual runs of power is for the simple fact that they added onto their system. In a lot of cases, a customer will start out with a 1000 watt sub amplifier setup, but still run their mid-highs off of head unit power. So a single 4 AWG is run for the sub amp. Then later down the road when they have the funds for a 4 x 150 4-channel amplifier, they add another 4 AWG for it. Because it would not make economical sense to pull out a perfectly good 4 AWG. A lot of my customers build their systems as they go.
A good rule of thumb by-the-way is that two cables of the same gauge, is equal to one cable three less in gauge. So two 4 AWG would be equal to one 1 AWG(not to be confused with 1/0 AWG). Or two 8 AWG is equal to one 5 AWG.
Edit: Also, two runs of 4 AWG is cheaper than one run of 1/0 AWG, and all of the distribution to go with it. Obviously it's a different story if you are actually pulling enough current to warrant the necessity of 1/0 AWG. Because in all reality, a single 1/0 AWG is pretty much equal to three 4 AWG
Modified by Broadfield at 12:22 AM 3/8/2010
