Wire Harness question
beezkneez
Car: one slow 240sx
Is the redtop harness compatible with the black top?
also will the ecu run with the black top if its from a red top..?
basic needing of understanding..
can I use a harness and ecu off of a red top to test and see if a blacktop will run?
thank you in advance
EnjoiNismo
Car: 93 240sx
I believe you can use the same ECU to "test."
