Wire diagram for 93 Q45t
fla.chris
Car: 1993 infiniti Q45t
I'm trying to install all new speakers in my 93 Infinity Q45t can anyone help me with the wiring diagram colors so I can install this. Or know of any web site that would be able to tell me. Or Have it all drawn out for me?????
I need front right +, - front left +, - rear right +, - rear left +, -
wire colors so I don't fry anything. I have all new Kenwoods to put in.
Any help would be apriciated!!! Thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
So OEM Clarion head unit or aftermarket? OEM wires or custom?
fla.chris
It's the factery wires that are still in the car I need to know what color wire goes to what speaker. I'm keeping all factory wires in the doors and in the rear. So I'm trying to figure out (for example: green/white stripe postive front left, green/blue stripe negative front left and so on......)
Q451990
Your profile says 94Q, but you're asking about a '93? Just curious because the FSM (factory service manual) is available for download for the '94+ at http://www.phatg20.net, and that will tell you the color codes.
Good luck!
Heath
Q451990
Oh, and if you need color codes for a '93, I think I would just look at each speaker and write down the color codes. Each speaker on the Q has a separate amplifier and is fed by four wires. Two wires for B+/Ground for the amp, and then audio +/-
You should be able to rule out the amplifier power by checking them with a volt meter, and I suspect they're the same color on each speaker/amp assembly. The audio wires should be a different color at each speaker... and the color codes should correspond with colors on the head unit harness.
Good luck!
Heath
