twistedsymphony »
https://forums.nicoclub.com/twistedsymphony-u62853.html
Tue Nov 24, 2009 9:17 am
so I took the dash apart in my vert with the intent to swap the analog cluster for a digital one.
While I was in there I also removed an anti-theft "secure key" attached to the key harness, (afaik it only touched the key harness).
The digital cluster didn't work so it sat in pieces for a couple of weeks. eventually I put the analog cluster back in and put the dash back together.
while the dash was apart I swapped the pop-up front for a silvia front with dual PJs... I didn't splice any wires I had sub-harnesses already made up from the guy I bought the front end from so it was all just plug'n play.
went to drive the car yesterday and the wipers wouldn't work... it's an intermittent switch and none of the functionality works (FWIW washers have never worked in this car because the pump isn't connected). the wipers DID work before the dash was taken apart, granted the last time I drove the car was a month or two ago...
this morning I-checked the plug at the wiper motor, it's clean, no breaks, clipped in snug, I reseated it for good measure-checked the plug at the stalk , it's clean no breaks, clipped in snug, I reseated it for good measure-pulled, checked, and reseated the fuse in the kick panel, it's good
I was going to check the wiper-amp too but it's not in the same spot as my S14 so I'll need to figure out where it is on this car.
Tonight or sometime later this week I'll pull out a multi-meter and the FSM and go through the whole damn thing, in the means time does anyone have any ideas what could be going on?
