neuticle »
https://forums.nicoclub.com/neuticle-u8876.html
Tue Apr 06, 2004 1:43 pm
Quote »will any other things stop working with the 20amp gone out?[/quote]the wiper fluid pump will also quit working, basically everything controlled off that stalk runs through that fuse.
if it's only the intermitant wiper control that doesn't work (fluid, high/low speeds work), and door chime doesn't work you might also want to check the timing control unit that's down around the fuse panel. but i really doubt that's the problem. check your fuse first.
