wiper problems
bongwater16
Hey guys, great site
I've been looking around the internet and can't find any answers to my problems, so maybe you guys can help. I have a 1990 240sx
Ok, #1 is when i push the button for the rear wiper, it will turn on, but to turn it off, i have to turn the car off
#2 is that the intermittent wipers dont work, high and low still work though
#3 is the most important, the front windshield washer doesnt work, i pull the knob thing, and nothing happens, the wipers dont move, the things dont spray, hower the back washer still works.
Ok, thanks in advance for any help you can give me.
drjohn
#1 could be the rear wiper amplifier behind the rear panel by the hatch latch in the body. If the wiper doesn't return to the park position the motor maybe defective. #2 maybe the switch itself or the frt wiper amp or time cotrol unit. #3 could be 2 problems the switch and or the washer motor. If not sure you might want to go to a reliable shop.
99gmcss
I HAVE A SIMILAR PROB.... but... I dont have a rear wiper... the cars front wipers dont come on. There is a short in the line because it continually blows the fuses, but only when you turn it on. It's almost as if there is a defective wiper motor or switch, but I can't be sure of which it is. I did a continuity test on the wiper motor and got nothing so I am assuming it's the motor. I even tried boost the amperage to 30amps from 20amps and it still blew the fuse... i am still not sure.... any ideas????
