Wiper Cowl Replacement DIY:
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
jspec603
Car: 92 verrrrrrrrrrrrrrrrrrrrrrrrrrrrrrt
cHello all!
Recently, my girlfriends new versa was damaged when a dead tree branch fell on it one windy night. We had the glass replaced a day or two later. Well, we finally got the new parts in from Nissan today.
New wiper cowl: $160 New passengers wiper arm $24
This replacement was pretty easy and straight forward. Here are some pictures to show more or less a step by step procedure.
Well, here is what we woke up to one morning after the windy night.
The new parts:
Now for the removal and replacement:
Step 1: Remove wiper arms. To do this you must first pry off the small plastic cover that conceals the 14mm nut. Once that cover is off, use a 14mm socket to loosen and remove the nuts. Then remove the wiper arms.
Step 2: Remove bottom windshield trim. These parts unclip and you will need 3M double sided tape to reinstall.
Step 3: Open the hood. On either side of the cowl, near the hood hinge, are 2 foam parts held on by heavy Velcro. Remove these to gain access to the push pins underneath. With a small screwdriver pop the pin open.
Step 4: There are 5 plastic clips that hold the bottom of the plastic cowl to the top of the fire wall. Remove these carefully, they break very easily. The best way I found to get them out is to take a small pair of needle nose pliers to separate the locking part of the clip, then pry out with a flat head screw driver.
Step 5: Gently pull cowl forward toward the engine, and raise it up enough to clear the attachment points for the wiper arms. Once clear, flip old cowl over and remove wiper fluid hoses and squirters. The squirters will also need pliers to help remove from cowl. Gently squeeze the clips on the squirters so that they can pass through the plastic.
Step 6: Remove weather stripping from old cowl and install on new part. Note: using pliers on the bottom of the retainer clips will help so you do not tear the weather stripping. Also at this point you can snap the wiper squirters back onto the new cowl as well.
Step 7: Reinstall in reverse order. Make sure you reattach the wiper fluid hoses and clip them into place on the plastic cowl. Also make sure the foam is correctly in place when sliding the cowl into place near the bottom of the glass.
Make sure all hoses are correctly routed, all clips are properly snapped back in place and your ready to reinstall the wiper arms. Make sure you try the wipers once or twice to see if they need any adjustment. Hopefully this will help at least one other person in the future!
Difficulty level: 1
Tools required: pliers, 14mm socket and ratchet, small flat head screw driver.
Time: 30-45mins start to finish.
AllieKat
Car: 07 Nissan Versa S HB
nice job jspec!!! thanks!!!
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
good diy, once you do this a few times like i have then you can do it blind folded....
brainguyus
Car: '12 Nissan Murano SL
'08 Nissan Versa SL
'67 Lincoln Continental
Well done! This will come in handy.
AbsentMinded
Car: 2009 Versa SL
Ditto--this was incredibly helpful. The windshield wipers are on a cone-shaped shaft. I couldn't pull them off straight but with a little rocking they popped off easily. Nissan should make something better than those plastic clips to hold the cowl on--metal clips would work better, but that would cost a few more pennies.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
You can also watch the "Front Lowering Springs" video on NissanVersaTech.com to see it on video, BTW.
Return to “Versa Technical Discussions”
