Postby
Rogue One »
https://forums.nicoclub.com/rogue-one-u185971.htmlFri Apr 04, 2014 10:03 pm
OEM size is 26" driver & 14" passenger. The service rep may have misread the specs. If you can't get the 14", some people have used 22" driver & 16" passenger. BTW, did you check the BOSCH website?
Yay thanks for responding. I was getting discouraged. I did check the Bosch website as well talked with someone at Bosch. He didn't really have an answer on why they don't make any 14".
So I should be able to do it your way?
Or what if I use 13" on the passenger side and 26" on the drivers side?
The other blades I was looking at were the Rain-x which they have normal size 14/26
